2014 RR LWB SCV8 Rear windows not working & USB port nonfunc
Hello all,
Just purchased a 2014 RR LWB SCV8.
Just drove it 1000 miles home without a hiccup. 78K miles from the original owner. Ran very smoothly and strong home.
I noticed the rear windows wont go up or down with any of the switches on the vehicle. Does anyone know where the fuse box is located or anything I should try? Not sure how to proceed.
Also the USB port in the center console doesnt work. Any advice?
Re: 2014 RR LWB SCV8 Rear windows not working & USB port non
I think the fuse for the USB port in the center console is located behind the glove box. Did you get the owners manual from the previous owner? If so, check the owners manual for the location of the rear window fuses as well as any other fuses that might need replacing.
Fuse box for the windows is behind the glove box.
Hello all,
I'm not sure about 2014, but MY 2016 has 2 USB ports in center console. The left one can be used for IPOD or USB Flash drive, but the right side can be used only to charge IPhone.
