What is the appropriate price for replacement headlight bulbs for a SE model?
I've seen prices vary from $45 - $250 for a replacement set.
Any guidance on brand would be appreciated as well.
Thanks!
2013-2015 Range Rover Sport
I went with these linked below. I will let you know how they work out. I posted several weeks ago wanting to know if anyone has changed a bulb and the procedure (I could not find any info via search). Maybe I will document my bulb change for future L494 owners.
Hi,
First remove the battery ground cable.
Then just remove the plastic trims above the headlamps, then the air cleaner units(left and right) to get access to the rear of the headlamp.
  • Like
Reactions: delray
Thank you SCar. I did not end up having to remove the right side air filter unit (was able to get my hand in their and twist the new light in fine without it). The left side - too tight, but easy to remove. Take the lid off via about 6 screws, and the bottom piece that holds the filter comes off with just one screw.
