I was driving home earlier this week on the interstate and my AC started emitting a chemical type smell and then the A/C system shut down. The entire system is no longer blowing any air, AC, or heat. Has anyone had a similar experience?
Probably the blower motor and resistor have failed. There should be many posts on here regarding fixing it (fairly easy replacement).
Visit the Autoguysland to review about the AC.
A blower motor may have a resistor problem. You should check the associated fuse/relay and then the diagnose the motor itself through physical inspection. Also, you can check the A/C system charge to ensure the system stays full. Hope you can figure out the issue and solve it.
