Hey guys,
My running boards came with the truck, and one has take a bit of a beating. Was wondering if it's pretty strait forward to remove them? And also, if I need any other pieces to replace and trim or parts that may have been modified or taken off when they were originally installed.
They are mainly bolt to the the frame. You'll want to remove both as you are unable to buy individual parts, only the entire set.
You mean both sides? Or both the running boards and any brackets there might be?
2010-2012 Range Rover Sport
I just finished doing this, the pain in the butt part was to remove side panel, because screw holding it was very tight. I had to remove the wheel. Besides that, easy work, about 20 minutes a side.
