Made it five miles from the dealer before the check engine light came on with the restricted power caution. 15 miles more it says it is low on coolant. Top it off with a 1/2 gallon, check it 15 miles later and put in another 1/2 gallon which may have overfilled it a bit. Engine light still on, a slow drip from somewhere I cannot see, so not at the reservoir or radiator nor the heater core. Parked all night, maybe three tablespoons dripped, drove five miles this morning and it is clear there is a small amount leaking somewhere that drops on the ground near the front, looks like under the plastic crossover near the smallest diameter hose. Tailpipe clear, no white smoke.
So, I am waiting on my buddys simple code reader to get here. As far as I can tell from the dash gauge the truck never got hot and the heater works fine on both driver and passenger sides. Doesn't smell hot, engine runs fine unless you try WOT and then it bogs down hard. Ease into the gas and it is smooth and seems normal.
Put Techtron super fuel cleaner bottle in this morning on a 1/2 tank, I will put a few miles on it in the next hour and then fill it up. Several posts here mention clogs in the fuel pump or rails can trigger these power restriction errors, and since the truck has put on only 300 miles in the last 2 years I see that as a prime suspect that might just clear up with some more driving and clearing the unknown codes. I have searched pretty hard here on this forum and the internet and see the causes are all over the place and they may take a while to run down. I ordered a code reader from Atlantic British to prepare for this journey.
The dealer is 120 miles away that I bought it from and I need to take it back there without doing any wrenching on it myself. They have the fancier code clearing devices for all European vehicles, and BTW - it passed emissions yesterday with no codes,...
***Just posting to get any advice from strangers on where the leak might be. They replaced the water pump, thermostat and the "cross over pipe" a few months ago. Perhaps a clamp didn't get tightened or an old hose sprang a tiny leak? What do you think? My fear is that their mechanic will want to keep it for a few days leaving me stranded a hundred miles from home.
San Diego car until two years ago when it arrived in Arizona, never seen weather or off road before at 116k miles. A real beauty.
Thanks for reading,
Rock
Thanks for reading,
Rock
