If you have seen this elsewhere, I have posted it to multiple forums.
I just came across, as the title suggests, a 2012 Range Rover HSE 5.0 that does not run. The first thing I did was put a new battery in it. It cranks, but does not start. When you push the start button with your foot on the brake it doesn't crank at all. But if you first turn the ignition on and then step on the pedal and press Start, it will crank but still not start. I ran codes with the GAP IID, and an overwhelming amount of codes from seemingly every module came up. I saved them and cleared the codes, everything came back. If anyone has the time, could you please look at this mess and tell me what ideas may be floating around out there? Thanks in advance, please see the codes below:
VIN: SALME1D48CA385661
L322 - Range Rover 2012
Vehicle scanned on 17-03-2021 15:09
Using IIDTool BT V4.0 B2691
AAM-Audio Amplifier
AAM-Audio Amplifier
- B1A01-13 (10) Speaker 1 circuit - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B1A02-13 (10) Speaker 2 circuit - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B1A09-13 (10) Speaker 9 circuit - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B1A10-13 (10) Speaker 10 circuit - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B1A03-13 (10) Speaker 3 circuit - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B1A04-13 (10) Speaker 4 circuit - General electrical failure - circuit open
- B1A07-13 (10) Speaker 7 circuit - General electrical failure - circuit open
- B1A08-13 (10) Speaker 8 circuit - General electrical failure - circuit open
- B1A11-13 (10) Speaker 11 circuit - General electrical failure - circuit open
- B1A12-13 (10) Speaker 12 circuit - General electrical failure - circuit open
- B1A05-13 (10) Speaker 5 circuit - General electrical failure - circuit open
- B1A06-13 (10) Speaker 6 circuit - General electrical failure - circuit open
- C0030-38 (50) Front left tone wheel - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
- C0031-25 (50) Front left wheel speed sensor - General signal failure - signal shape/waveform failure
- C0031-2F (50) Front left wheel speed sensor - General signal failure - signal is erratic
- C0031-31 (50) Front left wheel speed sensor - Frequency modulation/pulse width modulation failure - no signal
- C0031-62 (50) Front left wheel speed sensor - Algorithm based failure - signal compare failure
- C0031-64 (50) Front left wheel speed sensor - Algorithm based failure - signal plausibility failure
- C0033-38 (50) Front right tone wheel - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
- C0034-25 (50) Front right wheel speed sensor - General signal failure - signal shape/waveform failure
- C0034-2F (50) Front right wheel speed sensor - General signal failure - signal is erratic
- C0034-31 (50) Front right wheel speed sensor - Frequency modulation/pulse width modulation failure - no signal
- C0034-62 (50) Front right wheel speed sensor - Algorithm based failure - signal compare failure
- C0034-64 (50) Front right wheel speed sensor - Algorithm based failure - signal plausibility failure
- C0036-38 (50) Rear left tone wheel - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
- C0037-25 (50) Rear left wheel speed sensor - General signal failure - signal shape/waveform failure
- C0037-2F (50) Rear left wheel speed sensor - General signal failure - signal is erratic
- C0037-31 (50) Rear left wheel speed sensor - Frequency modulation/pulse width modulation failure - no signal
- C0037-62 (50) Rear left wheel speed sensor - Algorithm based failure - signal compare failure
- C0037-64 (50) Rear left wheel speed sensor - Algorithm based failure - signal plausibility failure
- C0039-38 (50) Rear right tone wheel - Frequency modulation/pulse width modulation failure - signal frequency is incorrect
- C003A-25 (50) Rear right wheel speed sensor - General signal failure - signal shape/waveform failure
- C003A-2F (50) Rear right wheel speed sensor - General signal failure - signal is erratic
- C003A-31 (50) Rear right wheel speed sensor - Frequency modulation/pulse width modulation failure - no signal
- C003A-62 (50) Rear right wheel speed sensor - Algorithm based failure - signal compare failure
- C003A-64 (50) Rear right wheel speed sensor - Algorithm based failure - signal plausibility failure
- C0051-28 (50) Steering wheel position sensor - General signal failure - signal bias level is out of range/zero adjustment failure
- C0062-54 (50) Longitudinal acceleration sensor - System programming failure - missing calibration
- C0062-64 (50) Longitudinal acceleration sensor - Algorithm based failure - signal plausibility failure
- C0063-14 (50) Yaw rate sensor - General electrical failure - circuit short to ground or open
- C0063-1C (50) Yaw rate sensor - General electrical failure - circuit voltage out of range
- C0063-28 (50) Yaw rate sensor - General signal failure - signal bias level is out of range/zero adjustment failure
- C0063-41 (50) Yaw rate sensor - System internal failure - general checksum failure
- C0063-49 (50) Yaw rate sensor - System internal failure - internal electronic failure
- C0063-4A (50) Yaw rate sensor - System internal failure - incorrect component installed
- C0063-64 (50) Yaw rate sensor - Algorithm based failure - signal plausibility failure
- C0063-86 (50) Yaw rate sensor - Bus signal/message failure - signal is invalid
- C0063-95 (50) Yaw rate sensor - Component failure - incorrect assembly
- C0063-96 (50) Yaw rate sensor - Component failure - internal failure
- C0064-64 (50) Roll rate sensor - Algorithm based failure - signal plausibility failure
- C006A-54 (50) Multi-axis acceleration sensor - System programming failure - missing calibration
- C101F-49 (50) Generic valve failure - System internal failure - internal electronic failure
- C1109-24 (50) Vehicle dynamics control switch - General signal failure - signal stays high
- C1A77-16 (50) Valve relay supply circuit - General electrical failure - circuit voltage below threshold
- C1A95-64 (50) Wheel speed sensor circuit - Algorithm based failure - signal plausibility failure
- C1A96-64 (50) Brake lamp switch circuit - Algorithm based failure - signal plausibility failure
- C1A98-2F (50) Yaw rate sensor circuit - General signal failure - signal is erratic
- C1A98-96 (50) Yaw rate sensor circuit - Component failure - internal failure
- C1B00-29 (50) Steering angle sensor - General signal failure - signal is invalid
- C1B00-64 (50) Steering angle sensor - Algorithm based failure - signal plausibility failure
- C1B00-92 (50) Steering angle sensor - Component failure - performance or incorrect operation
- C1B02-16 (50) Return pump circuit - General electrical failure - circuit voltage below threshold
- C1B02-49 (50) Return pump circuit - System internal failure - internal electronic failure
- C1B22-24 (50) Hill descent switch - General signal failure - signal stays high
- C2009-64 (50) Front axle wheel speed sensors swapped - Algorithm based failure - signal plausibility failure
- C200A-64 (50) Rear axle wheel speed sensors swapped - Algorithm based failure - signal plausibility failure
- U0001-88 (50) High speed CAN communication bus - Bus signal/message failure - bus is off
- U0074-88 (50) Control module communication bus B off - Bus signal/message failure - bus is off
- U0103-00 (50) Lost communication with gearshift module
- U0104-00 (50) Lost communication with speed control module
- U0123-00 (50) Lost communication with yaw rate sensor module
- U0126-00 (50) Lost communication with steering angle sensor module
- U3003-62 (50) Battery voltage - Algorithm based failure - signal compare failure
- C1A02-94 (50) Rotary encoder stuck in the intermediate position - Component failure - unexpected operation
- C1A01-96 (50) LED circuit - Component failure - internal failure
- C1A00-46 (50) Control module - System internal failure - calibration/parameter memory failure
- C1A56-93 (50) Front left tire pressure sensor and transmitter assembly - Component failure - no operation
- C1A58-93 (50) Front right tire pressure sensor and transmitter assembly - Component failure - no operation
- C1A60-93 (50) Rear left tire pressure sensor and transmitter assembly - Component failure - no operation
- C1A62-93 (50) Rear right tire pressure sensor and transmitter assembly - Component failure - no operation
- C1D21-05 (50) Wheel module - General failure information - system programming failure
- C1A58-16 (50) Front right tire pressure sensor and transmitter assembly - General electrical failure - circuit voltage below threshold
- C1A60-16 (50) Rear left tire pressure sensor and transmitter assembly - General electrical failure - circuit voltage below threshold
- C1A62-16 (50) Rear right tire pressure sensor and transmitter assembly - General electrical failure - circuit voltage below threshold
- C1A58-86 (50) Front right tire pressure sensor and transmitter assembly - Bus signal/message failure - signal is invalid
- C1A60-86 (50) Rear left tire pressure sensor and transmitter assembly - Bus signal/message failure - signal is invalid
- C1A62-86 (50) Rear right tire pressure sensor and transmitter assembly - Bus signal/message failure - signal is invalid
- U201F-87 (50) External receiver - Bus signal/message failure - missing a message
- U201F-11 (50) External receiver - General electrical failure - circuit short to ground
- U201F-12 (50) External receiver - General electrical failure - circuit short to battery
- C1D18-00 (50) Localisation failed
- B1182-51 (50) Tire pressure monitor system - System programming failure - not programmed
- C1A57-12 (50) Front left initiator - General electrical failure - circuit short to battery
- C1A57-14 (50) Front left initiator - General electrical failure - circuit short to ground or open
- C1A59-12 (50) Front right initiator - General electrical failure - circuit short to battery
- C1A59-14 (50) Front right initiator - General electrical failure - circuit short to ground or open
- C1A61-12 (50) Rear left initiator - General electrical failure - circuit short to battery
- C1A61-14 (50) Rear left initiator - General electrical failure - circuit short to ground or open
- C1A63-12 (50) Rear right initiator - General electrical failure - circuit short to battery
- C1A63-14 (50) Rear right initiator - General electrical failure - circuit short to ground or open
- B1D17-87 (50) Bus circuit - Bus signal/message failure - missing a message
- B112C-87 (50) Interior motion sensor - Bus signal/message failure - missing a message
- C111A-11 (50) Right stoplamp - General electrical failure - circuit short to ground
- C111B-11 (50) Left stoplamp - General electrical failure - circuit short to ground
- B1095-12 (50) Windshield wiper on/off relay - General electrical failure - circuit short to battery
- B11C2-11 (50) Power striker close relay - General electrical failure - circuit short to ground
- B11C2-12 (50) Power striker close relay - General electrical failure - circuit short to battery
- B11C2-13 (50) Power striker close relay - General electrical failure - circuit open
- B11C3-11 (50) Power striker open relay - Short circuit to battery/overload - General electrical failure - circuit short to ground
- B11C3-12 (50) Power striker open relay - Short circuit to battery/overload - General electrical failure - circuit short to battery
- B11C3-13 (50) Power striker open relay - Short circuit to battery/overload - General electrical failure - circuit open
- B1249-15 (50) Start button illumination - General electrical failure - circuit short to battery or open
- B1249-11 (50) Start button illumination - General electrical failure - circuit short to ground
- B12F5-12 (50) Fridge relay control - General electrical failure - circuit short to battery
- B1096-12 (50) Windshield wiper high/low relay - General electrical failure - circuit short to battery
- B1097-12 (50) Heated windshield relay - General electrical failure - circuit short to battery
- C2004-11 (50) Headlamp washer relay B - General electrical failure - circuit short to ground
- C2004-12 (50) Headlamp washer relay B - General electrical failure - circuit short to battery
- C2004-13 (50) Headlamp washer relay B - General electrical failure - circuit open
- B1C90-11 (50) Auxillary driving lamps relay coil circuit - General electrical failure - circuit short to ground
- B1C90-12 (50) Auxillary driving lamps relay coil circuit - General electrical failure - circuit short to battery
- B1C90-13 (50) Auxillary driving lamps relay coil circuit - General electrical failure - circuit open
- B10F8-11 (50) Accessory socket 'A' relay - General electrical failure - circuit short to ground
- B10F8-13 (50) Accessory socket 'A' relay - General electrical failure - circuit open
- B1102-11 (50) Enable crank relay short to battery (or relay always closed) - General electrical failure - circuit short to ground
- B136B-15 (50) Suspension control module wake-up signal - General electrical failure - circuit short to battery or open
- B1115-11 (50) High mounted stoplamp control - General electrical failure - circuit short to ground
- B111E-11 (50) Luggage compartment lamps - General electrical failure - circuit short to ground
- B111E-15 (50) Luggage compartment lamps - General electrical failure - circuit short to battery or open
- B113C-13 (50) Hazard switch illumination - General electrical failure - circuit open
- B113C-12 (50) Hazard switch illumination - General electrical failure - circuit short to battery
- B1140-11 (50) Engine crank authorisation - General electrical failure - circuit short to ground
- B136E-11 (50) Glove box release motor - General electrical failure - circuit short to ground
- B136E-15 (50) Glove box release motor - General electrical failure - circuit short to battery or open
- B12E7-23 (50) Glove box switch - General signal failure - signal stays low
- B1146-11 (50) Passive anti-theft sounder supply - General electrical failure - circuit short to ground
- B109C-11 (50) Front courtesy lamps - General electrical failure - circuit short to ground
- B109C-15 (50) Front courtesy lamps - General electrical failure - circuit short to battery or open
- B10EB-11 (50) Driver's door double locking motor - General electrical failure - circuit short to ground
- B10EB-15 (50) Driver's door double locking motor - General electrical failure - circuit short to battery or open
- B10ED-11 (50) Rear door driver side double locking motor - General electrical failure - circuit short to ground
- B10ED-15 (50) Rear door driver side double locking motor - General electrical failure - circuit short to battery or open
- B1108-11 (50) Driver's door central locking motor - General electrical failure - circuit short to ground
- B1108-15 (50) Driver's door central locking motor - General electrical failure - circuit short to battery or open
- B110A-11 (50) Rear door driver side central locking motor - General electrical failure - circuit short to ground
- B110A-15 (50) Rear door driver side central locking motor - General electrical failure - circuit short to battery or open
- B110C-11 (50) Rear door driver side power child locking motor - General electrical failure - circuit short to ground
- B110C-15 (50) Rear door driver side power child locking motor - General electrical failure - circuit short to battery or open
- B1161-15 (50) Rear left anti-pinch sensor - General electrical failure - circuit short to battery or open
- B1161-23 (50) Rear left anti-pinch sensor - General signal failure - signal stays low
- B1162-15 (50) Rear right anti-pinch sensor - General electrical failure - circuit short to battery or open
- B1162-23 (50) Rear right anti-pinch sensor - General signal failure - signal stays low
- B1163-11 (50) Left mirror heater output - General electrical failure - circuit short to ground
- B1163-15 (50) Left mirror heater output - General electrical failure - circuit short to battery or open
- B1164-11 (50) Right mirror heater output - General electrical failure - circuit short to ground
- B1164-15 (50) Right mirror heater output - General electrical failure - circuit short to battery or open
- B1165-11 (50) Front left puddle lamp output - General electrical failure - circuit short to ground
- B1165-15 (50) Front left puddle lamp output - General electrical failure - circuit short to battery or open
- B1166-11 (50) Front right puddle lamp output - General electrical failure - circuit short to ground
- B1166-15 (50) Front right puddle lamp output - General electrical failure - circuit short to battery or open
- B117C-07 (50) Rear door glass window up - General failure information - mechanical failure
- B117C-72 (50) Rear door glass window up - Mechanical failure - actuator is stuck open
- B117C-73 (50) Rear door glass window up - Mechanical failure - actuator is stuck closed
- B117C-92 (50) Rear door glass window up - Component failure - performance or incorrect operation
- B117D-72 (50) Rear door glass window down - Mechanical failure - actuator is stuck open
- B117D-73 (50) Rear door glass window down - Mechanical failure - actuator is stuck closed
- B117E-07 (50) Front power door glass window - Up - General failure information - mechanical failure
- B117E-72 (50) Front power door glass window - Up - Mechanical failure - actuator is stuck open
- B117E-73 (50) Front power door glass window - Up - Mechanical failure - actuator is stuck closed
- B117E-92 (50) Front power door glass window - Up - Component failure - performance or incorrect operation
- B117F-72 (50) Front power door glass window - Down - Mechanical failure - actuator is stuck open
- B117F-73 (50) Front power door glass window - Down - Mechanical failure - actuator is stuck closed
- B1189-29 (50) Front door glass window position sensor - General signal failure - signal is invalid
- B118A-29 (50) Rear window position sensor - General signal failure - signal is invalid
- B118C-04 (50) Left blind spot warning indicator - General failure information - system internal failure
- B118C-11 (50) Left blind spot warning indicator - General electrical failure - circuit short to ground
- B118C-12 (50) Left blind spot warning indicator - General electrical failure - circuit short to battery
- B118C-13 (50) Left blind spot warning indicator - General electrical failure - circuit open
- B118D-04 (50) Right blind spot warning indicator - General failure information - system internal failure
- B118D-11 (50) Right blind spot warning indicator - General electrical failure - circuit short to ground
- B118D-12 (50) Right blind spot warning indicator - General electrical failure - circuit short to battery
- B118D-13 (50) Right blind spot warning indicator - General electrical failure - circuit open
- B118E-00 (50) Front left door glass window
- B118F-00 (50) Front right door glass window
- B1190-00 (50) Rear left door glass window
- B1191-00 (50) Rear right door glass window
- B11B8-11 (50) Driver blind spot warning indicator supply - General electrical failure - circuit short to ground
- B11B8-15 (50) Driver blind spot warning indicator supply - General electrical failure - circuit short to battery or open
- B11D1-87 (50) Local interconnect network bus C - Bus signal/message failure - missing a message
- B11F6-11 (50) Driver folding mirror motor - General electrical failure - circuit short to ground
- B11F6-15 (50) Driver folding mirror motor - General electrical failure - circuit short to battery or open
- B1B70-83 (50) Local interconnection network bus circuit 2 - Bus signal/message failure - value of signal protection calculation is incorrect
- B1B70-86 (50) Local interconnection network bus circuit 2 - Bus signal/message failure - signal is invalid
- B1B70-87 (50) Local interconnection network bus circuit 2 - Bus signal/message failure - missing a message
- B1C09-11 (50) Driver's left/right mirror motor circuit - General electrical failure - circuit short to ground
- B1C09-15 (50) Driver's left/right mirror motor circuit - General electrical failure - circuit short to battery or open
- B1060-11 (50) Seat head restraint motor output - General electrical failure - circuit short to ground
- B1060-15 (50) Seat head restraint motor output - General electrical failure - circuit short to battery or open
- B1064-31 (50) Seat head restraint motor sensor - Frequency modulation/pulse width modulation failure - no signal
- B106D-24 (50) Head restraint up switch - General signal failure - signal stays high
- B106E-24 (50) Head restraint down switch - General signal failure - signal stays high
- B1B87-31 (50) Seat height motor speed/position sensor - Frequency modulation/pulse width modulation failure - no signal
- B1B89-31 (50) Seat slide motor speed/position sensor - Frequency modulation/pulse width modulation failure - no signal
- B1B91-31 (50) Seat tilt motor speed/position sensor - Frequency modulation/pulse width modulation failure - no signal
- B1B93-31 (50) Seat recline motor speed/position sensor - Frequency modulation/pulse width modulation failure - no signal
- U0142-00 (50) Lost communication with body control module B
- U0155-00 (50) Lost communication with instrument cluster control module
- B100F-25 (50) Video input B - General signal failure - signal shape/waveform failure
- B1010-25 (50) Video input C - General signal failure - signal shape/waveform failure
- U2101-4A (50) Control module configuration incompatible - System internal failure - incorrect component installed
- B102E-11 (50) Air quality sensor - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B102E-12 (50) Air quality sensor - General electrical failure - circuit short to battery
( on 29-10-2026 14:06:37 at 0 km ) - B1034-11 (50) Front left seat heater element - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B1034-15 (50) Front left seat heater element - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B1036-11 (50) Front right seat heater element - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B1036-15 (50) Front right seat heater element - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B1038-11 (50) Front left seat heater sensor - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B1038-15 (50) Front left seat heater sensor - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B103A-11 (50) Front right seat heater sensor - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B103A-15 (50) Front right seat heater sensor - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B10BA-11 (50) Rear blower control - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B11EE-11 (50) Air conditioning compressor - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B11EE-12 (50) Air conditioning compressor - General electrical failure - circuit short to battery
( on 29-10-2026 14:06:37 at 0 km ) - B11EE-13 (50) Air conditioning compressor - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B11FF-11 (50) Air conditioning refrigerant pressure - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B11FF-15 (50) Air conditioning refrigerant pressure - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B123D-11 (50) Dynamic stability control button - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B12A6-11 (50) Auxiliary heater water pump - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B12A6-15 (50) Auxiliary heater water pump - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B12AF-12 (50) Left coolant control valve - General electrical failure - circuit short to battery
( on 29-10-2026 14:06:37 at 0 km ) - B12AF-13 (50) Left coolant control valve - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B12B0-12 (50) Right coolant control valve - General electrical failure - circuit short to battery
( on 29-10-2026 14:06:37 at 0 km ) - B12B0-13 (50) Right coolant control valve - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B12B1-11 (50) Heated washer jet and wiper park relay - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B12B1-12 (50) Heated washer jet and wiper park relay - General electrical failure - circuit short to battery
( on 29-10-2026 14:06:37 at 0 km ) - B12B1-13 (50) Heated washer jet and wiper park relay - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B12B2-11 (50) Auxiliary heater coolant diverter valve - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B12B2-12 (50) Auxiliary heater coolant diverter valve - General electrical failure - circuit short to battery
( on 29-10-2026 14:06:37 at 0 km ) - B12B2-13 (50) Auxiliary heater coolant diverter valve - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B12B3-11 (50) Air quality sensor heater supply - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B12B3-12 (50) Air quality sensor heater supply - General electrical failure - circuit short to battery
( on 29-10-2026 14:06:37 at 0 km ) - B12B3-13 (50) Air quality sensor heater supply - General electrical failure - circuit open
( on 29-10-2026 14:06:37 at 0 km ) - B12B9-16 (50) Auxiliary heater control module - General electrical failure - circuit voltage below threshold
( on 29-10-2026 14:06:37 at 0 km ) - B12B9-17 (50) Auxiliary heater control module - General electrical failure - circuit voltage above threshold
( on 29-10-2026 14:06:37 at 0 km ) - B12B9-43 (50) Auxiliary heater control module - System internal failure - special memory failure
( on 29-10-2026 14:06:37 at 0 km ) - B12B9-49 (50) Auxiliary heater control module - System internal failure - internal electronic failure
( on 29-10-2026 14:06:37 at 0 km ) - U1000-00 (50) Solid state driver protection activated - Driver disabled
( on 29-10-2026 14:06:37 at 0 km ) - B1B72-12 (50) Local interconnection network bus 1 - power supply circuit - General electrical failure - circuit short to battery
( on 29-10-2026 14:06:37 at 0 km ) - B1C0A-11 (50) Control panel - Rear - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B1C30-12 (50) Disable switch - General electrical failure - circuit short to battery
( on 29-10-2026 14:06:37 at 0 km ) - B1D22-11 (50) Water temperature sensor circuit - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B1D22-15 (50) Water temperature sensor circuit - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B1D23-64 (50) Overheat sensor circuit - Algorithm based failure - signal plausibility failure
( on 29-10-2026 14:06:37 at 0 km ) - B1D24-11 (50) Glow plug circuit - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B1D24-15 (50) Glow plug circuit - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B1D24-64 (50) Glow plug circuit - Algorithm based failure - signal plausibility failure
( on 29-10-2026 14:06:37 at 0 km ) - B1D25-11 (50) Dosing pump circuit - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B1D25-15 (50) Dosing pump circuit - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B1D26-11 (50) Combustion air fan circuit - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B1D26-15 (50) Combustion air fan circuit - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B1D27-11 (50) Coolant pump circuit - General electrical failure - circuit short to ground
( on 29-10-2026 14:06:37 at 0 km ) - B1D27-15 (50) Coolant pump circuit - General electrical failure - circuit short to battery or open
( on 29-10-2026 14:06:37 at 0 km ) - B1D29-00 (50) No start, even after restart attempt
( on 29-10-2026 14:06:37 at 0 km ) - B1D32-00 (50) Multiple flame interruption during heating cycle
( on 29-10-2026 14:06:37 at 0 km ) - B1D33-00 (50) Flame interruption during normal operation
( on 29-10-2026 14:06:37 at 0 km ) - U0010-00 (50) Medium speed CAN communication bus
( on 29-10-2026 14:06:37 at 0 km ) - U0140-00 (50) Lost communication with body control module
( on 29-10-2026 14:06:37 at 0 km ) - U0164-00 (50) Lost communication with heating ventilation and air conditioning control module
( on 29-10-2026 14:06:37 at 0 km ) - U201A-56 (50) Control module main calibration data - System programming failure - Invalid / incompatible configuration
- B1009-51 (50) Ignition authorisation - System programming failure - not programmed
- B1009-87 (50) Ignition authorisation - Bus signal/message failure - missing a message
- B100D-64 (50) Column lock authorisation - Algorithm based failure - signal plausibility failure
- B1026-12 (50) Steering column lock - General electrical failure - circuit short to battery
- B12FE-13 (50) Fan - General electrical failure - circuit open
- B1A14-96 (50) Network management communication initialization - Component failure - internal failure
- U0010-88 (50) Medium speed CAN communication bus - Bus signal/message failure - bus is off
- U0139-00 (50) Lost communication with the suspension control module B
- U0159-00 (2F) Lost communication with parking assist control module
( on 17-03-2021 15:05:51 at 209875 km ) - U0300-00 (50) Internal control module software incompatibility
- U3000-46 (50) Control module - System internal failure - calibration/parameter memory failure
- U3000-49 (50) Control module - System internal failure - internal electronic failure
- B10C9-00 (50) Interior front antenna
- B10C8-00 (50) Interior center antenna
- B10C7-00 (50) Interior luggage compartment antenna
- B133D-00 (50) Loadspace/interior boot antenna
- B102B-00 (50) Passive key
- P2229-00 (50) Barometric pressure circuit high input
- P2228-00 (50) Barometric pressure circuit low input
- P0113-00 (50) Intake air temperature sensor 1 - circuit high input
- P0112-00 (50) Intake air temperature sensor 1 - circuit low input
- P00AD-00 (26) Intake air temperature sensor 1 - circuit high input - Bank 2
- P00AC-00 (50) Intake air temperature sensor 1 - circuit low input - Bank 2
- P0103-00 (50) Mass or volume air flow circuit high input
- P0102-00 (50) Mass or volume air flow circuit low input
- P010D-00 (50) Mass or volume air flow B - circuit high
- P010C-00 (26) Mass or volume air flow B - circuit low
- P0108-00 (50) Manifold absolute pressure/barometric sensor high input
- P0107-00 (50) Manifold absolute pressure/barometric sensor low input
- P0118-17 (50) Engine coolant temperature circuit high input - General electrical failure - circuit voltage above threshold
- P0117-16 (50) Engine coolant temperature circuit low input - General electrical failure - circuit voltage below threshold
- P018D-00 (50) Fuel pressure sensor B - circuit high
- P018C-00 (50) Fuel pressure sensor B - circuit low
- P0669-00 (50) Powertrain control module/engine control module/transmission control module internal temperature sensor - circuit high
- P0668-00 (50) Powertrain control module/engine control module/transmission control module internal temperature sensor - circuit low
- P0643-00 (50) Sensor reference voltage A - circuit high
- P0642-00 (50) Sensor reference voltage A - circuit low
- P0073-00 (50) Ambient air temperature sensor - circuit high input
- P0072-00 (50) Ambient air temperature sensor - circuit low input
- P2185-17 (50) Engine coolant temperature sensor 2 - circuit high - General electrical failure - circuit voltage above threshold
- P2184-16 (50) Engine coolant temperature sensor 2 - circuit low - General electrical failure - circuit voltage below threshold
- P0193-00 (50) Fuel rail pressure sensor high input
- P0192-00 (50) Fuel rail pressure sensor low input
- P0010-13 (50) Intake (A) camshaft position actuator - circuit open (bank 1) - General electrical failure - circuit open
- P2088-11 (50) Camshaft position actuator A - control circuit low, bank 1 - General electrical failure - circuit short to ground
- P2089-12 (50) Camshaft position actuator A - control circuit high, bank 1 - General electrical failure - circuit short to battery
- P0020-13 (50) Intake (A) camshaft position actuator - circuit open (bank 2) - General electrical failure - circuit open
- P2092-11 (50) Camshaft position actuator A - control circuit low, bank 2 - General electrical failure - circuit short to ground
- P2093-12 (50) Camshaft position actuator A - control circuit high, bank 2 - General electrical failure - circuit short to battery
- P0013-13 (50) Exhaust (B) camshaft position actuator - circuit open (bank 1) - General electrical failure - circuit open
- P2090-11 (50) Camshaft position actuator B - control circuit low, bank 1 - General electrical failure - circuit short to ground
- P2091-12 (50) Camshaft position actuator B - control circuit high, bank 1 - General electrical failure - circuit short to battery
- P0023-13 (50) Exhaust (B) camshaft position actuator - circuit open (bank 2) - General electrical failure - circuit open
- P2094-11 (50) Camshaft position actuator B - control circuit low, bank 2 - General electrical failure - circuit short to ground
- P2095-12 (50) Camshaft position actuator B - control circuit high, bank 2 - General electrical failure - circuit short to battery
- P001A-13 (50) Intake (A) camshaft profile control circuit/open - Bank 1 - General electrical failure - circuit open
- P001B-11 (50) Intake (A) camshaft profile control circuit low - Bank 1 - General electrical failure - circuit short to ground
- P001C-12 (50) Intake (A) camshaft profile control circuit high - Bank 1 - General electrical failure - circuit short to battery
- P001D-13 (50) Intake (A) camshaft profile control circuit/open - Bank 2 - General electrical failure - circuit open
- P001E-11 (50) Intake (A) camshaft profile control circuit low - Bank 2 - General electrical failure - circuit short to ground
- P001F-12 (50) Intake (A) camshaft profile control circuit high - Bank 2 - General electrical failure - circuit short to battery
- P0031-13 (50) Universal heated exhaust gas oxygen sensor heater control - circuit low (bank 1, sensor 1) - General electrical failure - circuit open
- P0031-11 (50) Universal heated exhaust gas oxygen sensor heater control - circuit low (bank 1, sensor 1) - General electrical failure - circuit short to ground
- P0032-12 (50) Universal heated exhaust gas oxygen sensor heater control - circuit high (bank 1, sensor 1) - General electrical failure - circuit short to battery
- P0051-13 (50) Universal heated exhaust gas oxygen sensor heater control - circuit low (bank 2, sensor 1) - General electrical failure - circuit open
- P0051-11 (50) Universal heated exhaust gas oxygen sensor heater control - circuit low (bank 2, sensor 1) - General electrical failure - circuit short to ground
- P0052-12 (50) Universal heated exhaust gas oxygen sensor heater control - circuit high (bank 2, sensor 1) - General electrical failure - circuit short to battery
- P240A-00 (50) Evaporative emission system leak detection pump heater - circuit open
- P240B-00 (50) Diagnostics module - tank leakage heater control - circuit low
- P240C-00 (50) Diagnostics module - tank leakage heater control - circuit high
- P0660-13 (50) Intake manifold tuning valve control - circuit open - bank 1 - General electrical failure - circuit open
- P0661-11 (50) Intake manifold tuning valve control - circuit low - bank 1 - General electrical failure - circuit short to ground
- P0662-12 (50) Intake manifold tuning valve control - circuit high - bank 1 - General electrical failure - circuit short to battery
- P0696-13 (50) Fan 3 control - circuit high - General electrical failure - circuit open
- P0695-00 (50) Fan 3 control - circuit low
- P0696-12 (50) Fan 3 control - circuit high - General electrical failure - circuit short to battery
- P219A-00 (50) Bank 1 - Air fuel ratio imbalance
- B10EC-11 (50) Passenger's door double locking motor - General electrical failure - circuit short to ground
- B10EC-15 (50) Passenger's door double locking motor - General electrical failure - circuit short to battery or open
- B10EE-11 (50) Rear door passenger side double locking motor - General electrical failure - circuit short to ground
- B10EE-15 (50) Rear door passenger side double locking motor - General electrical failure - circuit short to battery or open
- B1109-11 (50) Passenger's door central locking motor - General electrical failure - circuit short to ground
- B1109-15 (50) Passenger's door central locking motor - General electrical failure - circuit short to battery or open
- B110B-11 (50) Rear door passenger side central locking motor - General electrical failure - circuit short to ground
- B110B-15 (50) Rear door passenger side central locking motor - General electrical failure - circuit short to battery or open
- B110D-11 (50) Rear door passenger side power child locking motor - General electrical failure - circuit short to ground
- B110D-15 (50) Rear door passenger side power child locking motor - General electrical failure - circuit short to battery or open
- B11B9-11 (50) Passenger blind spot warning indicator supply - General electrical failure - circuit short to ground
- B11B9-15 (50) Passenger blind spot warning indicator supply - General electrical failure - circuit short to battery or open
- B11D1-83 (50) Local interconnect network bus C - Bus signal/message failure - value of signal protection calculation is incorrect
- B11D1-86 (50) Local interconnect network bus C - Bus signal/message failure - signal is invalid
- B11F7-11 (50) Passenger folding mirror motor - General electrical failure - circuit short to ground
- B11F7-15 (50) Passenger folding mirror motor - General electrical failure - circuit short to battery or open
- C1A31-01 (50) Front left corner valve - General failure information - general electrical failure
- C1A32-01 (50) Front right corner valve - General failure information - general electrical failure
- C1A33-01 (50) Rear left corner valve - General failure information - general electrical failure
- C1A34-01 (50) Rear right corner valve - General failure information - general electrical failure
- C1A35-01 (50) Reservoir valve - General failure information - general electrical failure
- C1A37-01 (50) Front cross-link valve - General failure information - general electrical failure
- C1A38-01 (50) Rear cross-link valve - General failure information - general electrical failure
- C1A13-64 (50) Pressure does not decrease when venting gallery - Algorithm based failure - signal plausibility failure
- C1A36-01 (50) Exhaust valve - General failure information - general electrical failure
- C1A24-67 (50) No temperature increase when compressor requested - Algorithm based failure - signal is incorrect after the event
- C1A18-64 (50) Pressure increases too rapid when filling reservoir - Algorithm based failure - signal plausibility failure
- C1A24-64 (50) No temperature increase when compressor requested - Algorithm based failure - signal plausibility failure
- C1A27-14 (50) Compressor circuit - General electrical failure - circuit short to ground or open
- C1A29-92 (50) Switch activation too long - Component failure - performance or incorrect operation
- C1A30-64 (50) Both switches pressed at the same time - Algorithm based failure - signal plausibility failure
- C1A03-26 (50) Front left height sensor - General signal failure - signal rate of change is below the threshold
- C1131-92 (50) Air supply - Component failure - performance or incorrect operation
- C1A03-92 (50) Front left height sensor - Component failure - performance or incorrect operation
- C1A04-26 (50) Front right height sensor - General signal failure - signal rate of change is below the threshold
- C1A04-92 (50) Front right height sensor - Component failure - performance or incorrect operation
- C1A05-26 (50) Rear left height sensor - General signal failure - signal rate of change is below the threshold
- C1A05-92 (50) Rear left height sensor - Component failure - performance or incorrect operation
- C1A06-26 (50) Rear right height sensor - General signal failure - signal rate of change is below the threshold
- U0133-00 (50) Lost communication with dynamic response module
- U0073-88 (50) Control module communication bus off - Bus signal/message failure - bus is off
- C1A06-92 (50) Rear right height sensor - Component failure - performance or incorrect operation
- C1B18-62 (50) Supply voltage x-ref check - Algorithm based failure - signal compare failure
- C1A07-62 (50) Cross articulation - Algorithm based failure - signal compare failure
- U3000-1D (50) Control module - General electrical failure - circuit current out of range
- C1A20-64 (50) Pressure increases too slow when filling reservoir - Algorithm based failure - signal plausibility failure
- U0136-00 (50) Lost communication with differential control module - rear
- U300D-01 (50) Ignition input on/start - General failure information - general electrical failure
- U2000-67 (50) Motor temperature - Algorithm based failure - signal is incorrect after the event
- U3000-1C (50) Control module - General electrical failure - circuit voltage out of range
- U2007-67 (50) Valve(s) circuit - Algorithm based failure - signal is incorrect after the event
- C1130-7A (50) Air spring air supply - Mechanical failure - fluid leak or seal failure
- C112F-72 (50) Air spring valve - Mechanical failure - actuator is stuck open
- C1130-66 (50) Air spring air supply - Algorithm based failure - signal has too many transitions/events
- C1138-23 (50) Access switch - General signal failure - signal stays low
- U1A14-49 (50) CAN initialisation failure - System internal failure - internal electronic failure
- U0300-55 (50) Internal control module software incompatibility - System programming failure - is not configured
- C0051-64 (50) Steering wheel position sensor - Algorithm based failure - signal plausibility failure
- B1D79-84 (50) Microphone input - Bus signal/message failure - signal is below allowable range
- P0561-1C (50) System voltage unstable - General electrical failure - circuit voltage out of range
- P0711-01 (50) Transmission fluid temperature sensor A - circuit range/performance - General failure information - general electrical failure
- P0938-29 (50) Hydraulic oil temperature sensor range/performance - General signal failure - signal is invalid
- P0713-12 (50) Transmission fluid temperature sensor A - circuit high input - General electrical failure - circuit short to battery
- P0712-11 (50) Transmission fluid temperature sensor A - circuit low input - General electrical failure - circuit short to ground
- P0710-13 (50) Transmission fluid temperature sensor A circuit - General electrical failure - circuit open
- P0711-22 (50) Transmission fluid temperature sensor A - circuit range/performance - General signal failure - signal amplitude>maximum
- P0713-01 (50) Transmission fluid temperature sensor A - circuit high input - General failure information - general electrical failure
- P0717-12 (50) Turbine/input shaft speed sensor A circuit no signal - General electrical failure - circuit short to battery
- P0716-14 (50) Turbine/input shaft speed sensor A - circuit range/performance - General electrical failure - circuit short to ground or open
- P0716-22 (50) Turbine/input shaft speed sensor A - circuit range/performance - General signal failure - signal amplitude>maximum
- P0716-21 (50) Turbine/input shaft speed sensor A - circuit range/performance - General signal failure - signal amplitude<minimum
- P0721-64 (50) Output shaft speed sensor - circuit range/performance - Algorithm based failure - signal plausibility failure
- P0721-27 (50) Output shaft speed sensor - circuit range/performance - General signal failure - signal rate of change is above the threshold
- P0963-12 (50) Pressure control solenoid A control - circuit high - General electrical failure - circuit short to battery
- P2763-12 (50) Torque converter clutch pressure control solenoid control - circuit high - General electrical failure - circuit short to battery
- P0740-13 (50) Torque converter clutch solenoid - circuit/open - General electrical failure - circuit open
- P0971-12 (50) Pressure control solenoid C control - circuit high - General electrical failure - circuit short to battery
- P2721-12 (50) Pressure control solenoid D control - circuit high - General electrical failure - circuit short to battery
- P2730-12 (50) Pressure control solenoid E control - circuit high - General electrical failure - circuit short to battery
- P2739-12 (50) Pressure control solenoid F control - circuit high - General electrical failure - circuit short to battery
- P092C-11 (50) Gearshift lock solenoid - Circuit B low - General electrical failure - circuit short to ground
- P092B-14 (50) Gearshift lock solenoid - Circuit B - Range/performance - General electrical failure - circuit short to ground or open
- P0930-11 (50) Gearshift lock solenoid - circuit A low - General electrical failure - circuit short to ground
- P0929-14 (50) Gearshift lock solenoid - circuit range/performance - General electrical failure - circuit short to ground or open
- U3001-94 (50) Control module improper shutdown - Component failure - unexpected operation
- P2700-07 (50) Transmission friction element A apply time range/performance - General failure information - mechanical failure
- P2701-07 (50) Transmission friction element B apply time range/performance - General failure information - mechanical failure
- P2702-07 (50) Transmission friction element C apply time range/performance - General failure information - mechanical failure
- P2703-07 (50) Transmission friction element D apply time range/performance - General failure information - mechanical failure
- P2704-07 (50) Transmission friction element E apply time range/performance - General failure information - mechanical failure
- P0731-07 (50) Gear 1 incorrect ratio - General failure information - mechanical failure
- P0732-07 (50) Gear 2 incorrect ratio - General failure information - mechanical failure
- P0733-07 (50) Gear 3 incorrect ratio - General failure information - mechanical failure
- P0734-07 (50) Gear 4 incorrect ratio - General failure information - mechanical failure
- P0735-07 (50) Gear 5 incorrect ratio - General failure information - mechanical failure
- P0729-07 (50) Gear 6 incorrect ratio - General failure information - mechanical failure
- P0736-07 (50) Reverse incorrect ratio - General failure information - mechanical failure
- P0781-07 (50) 1-2 shift - General failure information - mechanical failure
- P0782-07 (50) 2-3 shift - General failure information - mechanical failure
- P0783-07 (50) 3-4 shift - General failure information - mechanical failure
- P0784-07 (50) 4-5 shift - General failure information - mechanical failure
- P0829-07 (50) 5-6 shift - General failure information - mechanical failure
- P0829-77 (50) 5-6 shift - Mechanical failure - commanded position is not reachable
- P0784-77 (50) 4-5 shift - Mechanical failure - commanded position is not reachable
- P0783-77 (50) 3-4 shift - Mechanical failure - commanded position is not reachable
- P0782-77 (50) 2-3 shift - Mechanical failure - commanded position is not reachable
- P0781-77 (50) 1-2 shift - Mechanical failure - commanded position is not reachable
- P0741-07 (50) Torque converter clutch solenoid - circuit performance or stuck off - General failure information - mechanical failure
- P0121-86 (50) Throttle/pedal position sensor A - circuit range/performance - Bus signal/message failure - signal is invalid
- P0219-86 (50) Engine overspeed condition - Bus signal/message failure - signal is invalid
- U0401-64 (2E) Invalid data received from engine control module/powertrain control module - Algorithm based failure - signal plausibility failure
( on 17-03-2021 15:05:59 at 209875 km ) - P081C-62 (50) Park input circuit - Algorithm based failure - signal compare failure
- P081C-64 (50) Park input circuit - Algorithm based failure - signal plausibility failure
