2010 SC 5.0 Range Rover MkIII / L322
sounds like the chains, tensioners and guides if you swap out the parts also include the 4 VVT units
What makes you say that? The tapping is a very different tone than others I've heard. If I read you correctly, this sounds like an immediately urgent issue. However, I am not throwing a Check Engine light.
John
It kind of sounds like a bad water pump, they last 40ish thousand miles.. timing guides don’t always through a code
can't edit post, disconnect the main belt and listen for change, I'll cross my fingers that it is only a pump and not a $5000 job....
and throw not through....thank you Apple haha
Discussion Starter · #6 ·
Thank you. Any guidance (or a link) on how to disconnect that main belt? Are you talking about the main serpentine belt that would run the alternator, AC, SC?
