1 - 20 of 24 Posts
i did this for my FF and thought it wld be helpful to people here. 2011 SC delivered Nov 2010
nov 2011 - 7,851 miles
15k service
$0
Jan 2013 - 20,578 miles
30k service $811
Front and rear pads and rotors $2,131
$3,246.34
Dec 2013 - 33,770 miles (independant)
oil change $210
Front and rear pads $340
$622.00
Feb 2014 36,002 miles (dealer)
dynamic suspension light on - found wires at strut tops broken and replaced upper harness
$0
Sept 2014 41,322 miles (dealer)
car doesnt start - towed to dealer
download tune ECU
$0
October 2014 42,200 miles (inde)
Annual service $150
Front and Rear pads $300
$450
March 2015 48,387 miles (dealer)
horns not working - replaced both
seats dont retain memory with both keyts
$825
August 2015 52,221 miles (dealer)
Front brake hose
$0
November 2015 55,276 miles (inde)
annual service
$391
November 2016 63,789 miles (inde)
annual service
replace drive belts
cabin and air filter
$1,214
July 2017 69,685 miles (inde)
water pump
$400
November 2017 72,526 miles (inde)
annual and plugs
$700
August 2018 79,626 miles (dealer)
takata air bag and check timing chain
$0
so thats about $7,848 without tires.
Discussion Starter · #2 ·
so was flipping through the owners manual/maintenance book. Im 96 months into the cars life but just hitting 83k miles. i did filters and belts 2 years ago and plugs 12 months ago. shld i even bother having the 96 month service done?
What was up with the brakes?
In my opinion, for a full-size RR, <$8,000 in 8 years isn't too bad.
The main items for the 96 month (120,000 mile / 192,000 km) service is really just the oil change and pollen filter change. I'm assuming you're on top of your oil changes but if the last time you changed your cabin filter was 2 years ago, go have a look at the filter (pull it out yourself) and see how dirty it is.
Discussion Starter · #6 ·
Agrees the car has been very reasonable so far. Hopefully the extended warranty i just bought will cover the timing chain when that needs to be replaced.
Great Thread. Very helpful info. I’m looking at getting a 2012 SC and it’s nice to see some actual real world numbers. Thanks for posting. I’m finding several 2012 with about 50K miles
ill be sure to listen for timing chain slap.
Discussion Starter · #9 ·
ur welcome. also worth noting i switched to Hawk pads around 45k miles and they last much longer than oem pads.
Discussion Starter · #12 ·
here is what annual oil changes gets you:
Blackstone oil analysis summary
"This report holds plenty of good news for the 5.0L engine powering your Ranger Rover. Typicalwear for the engine type is on the far right, based on ~7,500 miles of oil use. Iron is elevated slightly, but
that's normal for the mileage on the oil. Other metals should be about average, mileage aside, and you've
got that too. Taken altogether, these are healthy wear numbers. The trace of fuel isn't a concern, even if it
thinned this 5W/30 a little. Often, a trace is from cold sampling. The TBN read 3.1 - plenty of active additive
left (1.0 is low). Try ~17k miles."
I just bought the warranty. It covers:
I'm not sure if I missed it, but what company did you go with?
Discussion Starter · #14 ·
carshield - i tried getting the timing chain done and they said the engine was low on oil. so i canceled the warranty and found a LR tech to do the work on the side.
Plus 80K depreciation, that is the real cost of having RR 88K in 8 years(I'm talking about mine). = 11k per year = ~1k per month
Hello,
Regarding the oil analysis, was that Castrol Professional OE or another 5w30? And how many miles were on that sample?
Travis
Good to know. Thanks! I was curious about the TBN after that many miles. I'll be sending in a sample of the 0w20 in a few months...
Travis
1 - 20 of 24 Posts
