1 - 1 of 1 Posts
So i was driving 2011 Sport Supercharged and music turned off, then nav screen got black, then turn signals would not work, windows not going up and down.
I parked the car shut it off and then decided to start it again,and it did not, i had speedo lights on first attempt, on second attempt keys not found.....
Codes that i have
U0010-88 Medium speed can communication bus
U0013-00 Medium speed can communication bus (+) low
Checked all the fuses, tried different instrument cluster, did not helped, battery is 12.7v, tried to program different key was not even able to connect to the KVM module.
Right now i am in the process of taking of the dash to check the wiring.
Would appreciate any suggestions and advices
Thank you
1 - 1 of 1 Posts
