Howdy!
My back license plate lights are out. Replaced the bulbs and they are still not working. Looked in the manual to check the fuses and can't find the right fuse. Can someone assist me please so I can have lighted license plates again? BTW I looked at the forums and cant find a thing!
SUPER MODERATOR
The lights are bladed, so you may have inserted them backwards. Flip them around and check again. If not...it's a fuse, look in your manual at the end, it will indicate the proper fuse.
I have tried that and they are still not working. Also it seems that we can only install them one way. I checked the manual and cannot find an answer for the fuse.....which one (what number) is it?
This is from my RRS PDF on my computer. I have an 09 so yours may not be the same. FWIW
Fuses
270
Tow hitch fuses
The supplementary fuse box that protects the
tow hitch circuits, is located under the cover in
the luggage compartment.
LAN0359G
1
2 3
4
5 6
Fuse
number
Rating
(amps)
Circuit protected
1 7.5 Brake lamp
2 15 Ignition feed
3 15 Battery feed
4 7.5 Rear fog lamps
5 5 Right-hand tail lamp
6 5 License plate and
left-hand tail lamp
