1 - 9 of 9 Posts
Hi guy's,
When i brought my 2011 range rover the bluetooth didn't work, upon investigation the most connector was looped so i assumed that the module was faulty I plugged it in & got the flashing power button problem.
I then ordered a replacement module from eBay and plugged it in & I get the same problem.
Does anyone have any ideas? I would welcome any advice..
Many thanks
Ash
Not sure if they are serviceable but you could check with your local electronic repair dude. Some of those folks can fix anything.
i would start by trying to find someone with the same vehicle and plugging yours in to test it. This is likely the easiest thing you will ever do on your RR. Takes less than 60 seconds.
i had issues with my stereo components in my 04 L322 due to a water leak and found a guy in Birmingham so not to far from you that was able to fix it, in fact he fixed it within an hour, he also added bluetooth phone and streaming of music via the AUX mode on the stereo. I will PM you his details.
Hi guy's,
Many thanks
Ash
I see 'envogue' hasn't been online in the forum for sometime......
Can anyone else please post / send the details for the guy in Birmingham who is able to repair L322 bluetooth modules?
I've just acquired a 2010 TDV8 and couldnt get the bluetooth to be found by my phone. I also discovered a MOST bypass on the plug which should be in the bluetooth module.
Thanks!
Richard
1 - 9 of 9 Posts
