Hey guys,
I have a 2010 RRSC with a 2097 Bank one....
Cleaned the MAF's, code took a lot longer to come back but eventually it did.
Looking at o2 sensors, and wondering about what are regular 02 sensor behaviour...
If I monitor the engine, what should I be seeing on my O2 sensor fluctuation in voltage... To determine if they need replacement?
I have read that after CAT o2 will level out and stay constant, mine are still bouncing around a bit...
Thanks in advance!
2010-2012 Range Rover Sport
Hey guys,
Thanks in advance!
What is the 2097 code? And what are using to monitor voltage? The GAP tool?
Once O2's go bad the voltage fluctuation slows down a lot. A new O2 will have voltage that swings extremely rapidly, basically the voltage will almost look like a "blur" to our eyes since it's changing so fast.
Since it sounds like you have some kind of monitoring capability, how do your fuel trims look?
Two part series on fuel trims-- excellent--
https://www.youtube.com/watch?v=5WnM_NsOtd8
From P2097 search
How to Fix
  • Check the PCV hoses and vacuums for damages, replace components if necessary.
  • Clean the MAF sensor. ...
  • Check the fuel lines for cracks, pinches or leaks.
  • Inspect the fuel pressure at the fuel rail.
  • Inspect the fuel injectors for dirt. ...
  • Inspect the exhaust leak located before the first O2 sensor.
I doubt it is the O2 sensors. They will produce a code of their own if not functioning correctly
