2010-2012 Range Rover Sport
Shortly after started getting massive vibration as I exceeded 80kph. This happened two nights ago and this morning I did the unjam procedure using the IIDTOOL and it helped. I’m guessing that because I don’t use the electronic PB all the time, it’s starting to seize.
Anyone else run into this issue?
Nothing yet to report here, but I never exceed 80kph with my supercharged rover never.....8)
I remember reading/hearing that you should try to engage this p-brake whenever you
can from time to time...for all reasons - to keep it aligned and functioning - could
be a myth though...
Discussion Starter #3 (Edited by Moderator)
Not a myth, you’re right. The mechanism will seize after a while if you don’t use it which is what I have not been doing. Not sure if I can start using it again without causing further damage.
Dammit! Happened again last night when I went to get gas. Oddly enough it went away after the first few minutes of driving
