I have 2010 RRS supercharged. For the past 6 months the alarm goes off consistently 15-20 minutes after I lock the car for no apparent reason. Pretty annoying. Does anyone else have a solution to this?
The usual suspect is the hood sensor. Cheap to replace or simply disconnect it to see if that is the issue. Do you not have a message on your display for what triggered?
I typically do not see a message for what triggered it. But makes sense. The hood sensor goes off/on a lot when I am driving. It will just happen for a few seconds. How would I disconnect or replace it?
I had the same issue. Very easy fix. That video is great. I got the part on Amazon a little less expensive than on AB though.
