1 - 18 of 18 Posts
2010-2012 Range Rover Sport
My air condition been acting up lately. When car is park or at a stop at regular idle, air condition seems to blow cool (not cold) or warm air. Air condition comes back real cold when the truck is actually running. Anybody ever else had this problem? Freon is good and condenser is free of debris. This is making me scratch my head.
I’ve had this problem and I was looking for answers but couldn’t find any. Later on I found out that my fan clutch wouldn’t engage the way it should. The way it was explained to me is that the fan has 2-3 settings pretty much low, medium, high. I’m not sure if it’s true or not but since it has been replaced no more warm air. Hope that helps
So you replaced the AC compressor? I’m not to sure if you can replace the clutch itself. How much was it to replace if you don’t mind me asking?
just reread your reply and you said fan clutch not ac compressor clutch. May I know where is that located cause there only one big fan which behind the radiator.
No I replaced the cooling fan and it’s one piece when you buy new, fan and clutch, on some websites it’s says fan and motor. It cools down the A/C condenser so if it doesn’t work properly it could be the reason why you’re getting warm air and while you drive the air cools it down. When I bought it it was about $680 but now Land Rovers dealers are starting to their own parts websites which is sometimes a lot cheaper than other online stores. I bought few things from Land Rover of Fort Mayer’s online catalog but you can find a dealer somewhere closer to you. Price I see there is $440 for non SC and $540 for the SC.
Ok. Thanks!
im just wondering tho...let’s say the fan is stuck on low speed, then I would have overheating problem right? I guess I gotta keep an eye on that fan to see if she change speed.
I would think so as well but I had same problem as you and never had an overheating issue and then it finally did one day and that’s when I said this is it and replaced it. It’s really easy to do yourself but you need the clutch removal wrench which is 36mm and you can get on amazon. Never had any issues since
I guess it’s time to shell out money and replace the fan. Thanks mang!!
Definitely worth it, you’ll have cold A/C and won’t have to worry about overheating somewhere on the road possibly damaging the engine
There is a workshop manual posted here couple posts down, download it and you’ll have instructions on how to do it, remove the intake, fan shroud and you’ll have access to the fan, make sure you unplug it first and then use a 36mm fan clutch wrench (regular wrench is to thick) and you might want to buy one, some auto parts let you borrow but they are usually worn out and you don’t wanna round the nut. And if you buy a set it will come with another tool to hold the pulley from spinning, there is bunch of YouTube videos as well so look those up
kosep, most likely it is refrigerant control valve (RCV) in the a/c compressor. take look at this link. I replaced mine and all is good now.
https://www.fullfatrr.com/forum/topic43778.html
Discussion Starter #14
Interesting! Thank you...
did you replace the ac compressor or just change the sticky valve?
The original fan and clutch assembly is made by Behr Hella. I found the Behr Hella fan for a lot less $$ than the one from Land Rover.
Discussion Starter #17
Is your car 2010 rrs also? May I know the part number please
1 - 18 of 18 Posts
