I have a new to me 2010 HSE with 124k miles. I first got a code for a misfire at cylinder 4. I reset it then came back with a few cylinders. Then the CEL went off on its own. Once again it showed up in multiple cylinders. I read about the BG44k cleaner as suggested by Land Rover. I ordered a can which didn't arrive before going on a little road trip of about 500 miles. So i used Techtron. I cleared the codes (icarsoft LRII) and put in one bottle and then a second one on the next fill up (same road trip). No lights as of yet. Seems ok now. When I was getting the codes there was no noticeable misfires or shaking. Although I did feel a slight hesitation when accelerating at times. Almost like driving on a washboard. Like I said, all seems ok now. Just throwing this out there for others before they throw money at coil packs, injectors, etc..Not saying it will cure yours, but as Land Rover suggests, try a good cleaning first.
Wish me luck and the same to you.
I like to do SeaFoam treatments every 4-6 months on newly acquired vehicles with high mileage, and then once a year from there on out. It is good to clean off the carbon build up on the injectors and pistons.
That sad, that washboard type rumble was the symptom when my cylinder #2 plug was extremely fouled.
FWIW the 2010 on Petrol engines are direct injection SO the intake system can get carboned up and not much can clean it except intake removal
The BG44 in the gas will assist in keeping the injectors clean
Did you perform a timing chain swap and now have misfires? I had the dealer do this and get the rough idle now
I have no idle issues, completely smooth both my SC (with rebuild) or HSE (no rebuild).
Yep, I changed chains and now have misfires(it shows CEC light every second day) and rough idle(only when transmission in D).
from my research most probable is a fouled up injector seal or injector.
I was also instructed to look into the wire harness connectors at the rear of the left cylinder head.
Mine is a comes and goes type of shudder like possibly its an intake leak. I put 2 can of BG 44 and 2 bottle of techron into the fuel but no changes
