I've done all the tricks to remove it ,angled it 45deg to line up pin,still not coming off.What am l doing wrong.:shock:
SUPER MODERATOR
Why on earth would you start a second thread for the same issue you already posted about and received advice? the advice in the previous thread was accurate, remove the trim, remove the bolt and naturally it is going to be stuck as it's been on there since the seat was assembled before it even gt the LR for assembly. you just need to wiggle it around abit at appx 45 degrees until it pops loose. if you are doing something else we would have no idea but I can guarantee the advice you were given before works because I have taken them off my self to install the waterproof seat covers.
