I'm currently driving a 2010 L322 HSE with 80k miles that hasn't had any issues until the red Suspension System Inactive came on. The suspension immediately dropped to the bump stops and remained there since. This was preceded the day before with the amber Suspension System Fault that went away overnight. The next stop was an independent mechanic who has serviced the vehicle before since there is not a local deealership.
Two DTC codes came up when I checked the system:
C1130-66 (6C) Air spring air supply - Algorithm based failure - signal has too many transitions/events (amber warning light)
C1130-7A (2E) Air spring air supply - Mechanical failure - fluid leak or seal failure (red warning light)
The mechanic went over the suspension and said that the right front strut/air spring ($1,100 for non-OEM w/active dampening) is not holding air and needs to be replaced. He also said that there is a technical bulletin that recommends replacing the compressor relay, drier and delivery valve kit on the compressor to remedy the C1130-7A (2E) code. He said the kit itself is $1,200-$1,400, which doesn't sound right considering a whole new non-OEM compressor is available for $730 at Atlantic British. Labor for both is only a couple of hours and was reasonable.
Couple of questions:
1) Do the codes in parentheses above indicate where the fault was generated (6C) & (2E)? What do they mean or can you direct me to a resource that would tell me?
2) What are the chances that just replacing the front right strut clears both codes without the compressor rebuild? Mechanic didn't indicate that there is a problem with the compressor, only that he saw a TSB associated with the DTC code.
3) How difficult is it to fit the TSB kit or replace the compressor myself? Any new software needed or just a calibration using the GAP IID diagnostic tool?
I would not attempt to replace the strut/air spring myself because I have no access to a lift, among other things. I've done much of the routine maintenance on the vehicle and would consider working on items that don't require a lift.
I've owned this vehicle for a number of years and have been looking to sell/trade it this spring, so any advice to get the vehicle back into a condition to trade with the least amount of expense is appreciated.
Thanks,
Thanks,
