Hello,
I have a 2010 Range Rover HSE that had a persistent Suspension Fault error show up. I've had this code for almost a year now without any issues with ride height. I've decided to try and fix the code as I want to sell it in the near future. The compressor is a Hitachi style and I purchased a replacement along with relay. I swamped the compressor and drove it around a few miles and the Suspension Fault didnt show up. Parked the vehicle and an hour later drove it again and fault code started showing up after a few minutes while parked. I hear the compressor going then turns off. Vehicle is set to the correct right height and viewed it in the 4x4 screen on the display to check all ride height sensors and it is accurate. I am at a loss here because I have taken this to an independent shop that recommended changing the compressor as the fault code was reading that it was filling up too fast which makes the suspension fault appear.
At this point I am not sure what else I should be checking.
I am going to try to disconnect the battery and have it sit for a bit to see if that will reset the fault code.
If anyone has other recommendation on next steps I would really appreciate it.
Thank you.
Thank you.
