2016 Range Rover Sport HSE, 2016 Range Rover Supercharged, 2012 Range Rover Supercharged
Hey everyone,
Both of my keys have the rubber portion separating from the remote. One is pretty bad and now the second one is just starting. Does anyone know of a solution to fix rather than having to buy a replacement key? Would a plastic/rubber glue work?
All the best.
Are referring to the back panel and button panel edges? You can get front and rear replacement panels to fit to your existing chrome housing for the battery, electronics and blade key. LR052905
Yes! Thank you for the tip!
Good tip - that's what I did with both of my keys. You can take the old keys apart and use the PCBA and side metal pieces in the new one.
