When looking up parts for my 2013 RR Sport HSE LUX I see a clear distinction between
the years 2010-2011 and 2012 - 2013.
As an example my OEM hitch wiring kit was advertised as only fitting years 2012-2013.
I have seen kits for 2010-2011 only.
So what are the differences between these MY 2010-2011 and 2012-2013?
When ever you have a change in any system that has an add on accessory the accessory must change as well. The difference is most likely a change in lighting or communications related in conjunction with how the vehicle responds to the trailer kit being plugged in. Could also be as simple as a change in the gauge of wire used.
