1 - 12 of 12 Posts
Front Windshield, Rear Windshield, Headlight Washer's not working. I have checked the fuse, at least I think I checked the right one No noise from the pumps at all. I have a hard time thinking all three pumps are bad (I think this model has three). Is there a relay or something else that could cause this problem? Just purchased the Range two weeks ago and happened to finally need to try them when I found they didn't work. Any help would be appreciated.
So which fuse did you check? The fuse for the washer pumps is located behind the glove box. You have to remove everything in the glove box, open the box, then depress the guides on the side so the box swings all the way down to provide access to the fuse panel. Washer pump is fuse #11 (15 amp).
If you have already done this report back and I'll see if I can pull up a wiring diagram.
I just double checked Fuse #11 (15 AMP). It is good. I also checked a fuse under the hood that was labeled "heated washer fluid" and it was also good. The switch seems to be okay because when you push either to wash front or rear window, the wipers wipe three times. I am at a loss. Could it be a computer issue/bcm issue?
I doubt it is a computer issue. It could be a bad relay. I think the relay for the washer pump is under the hood. I'll look it up and let you know. I also have the wiring diagram I'll post that as well.
Hook up a voltmeter to the plug the pump and see if you get an input? Not sure how easy that tank is to get to--its behind the bumper cover on the driver side...I don't know if you can get to it thru the wheel well splash cover...last time a saw mine was when I had the bumper cover off.
There could be a stored code for the washer system if you can get it checked.
The connector to the washer pump is on the left, may be accessible through the wheel well by removing the splash guards - could check the circuit there too.
Hi Bigpemby
How did you go fixing your problem with the washers my RRS has just developed the exact same problem.
Thanks in advance.
1 - 12 of 12 Posts
