When I active the window switch it just does one click after pressing it up and down once. All other windows go down and back up. Have not checked the common floor sill problem but will be soon. Any suggestions on what else I may be looking at?
Sometimes the window motors need resetting, mine had this on the passenger side. If what you mean is that you click the window up or down and instead of travelling the whole distance it just moves one click, then this might solve it.
Roll the window totally up and release the switch, then pull the switch (to roll up the window) and hold it until you hear a slight 'click' sound. The motor will reset at this point, and it should travel automatically as expected.
Worked for me, hope it works for you too!
Mine was the wiring in the sill - but check the connections to the ecu under the drivers and passenger seat , fuses (I forget if all windows route through same fuse).
