Hello,
I have a 2008 Range Rover HSE with the three amigos lights and inoperable ride height / traction controls. Using a scanner to diagnose this issue I found that the only codes being logged were against the Front Passenger and Rear Passenger ABSensors. Moving to the rear first, I traced the wire and found a break in the wires which I repaired resolving that end of the circuit. Doing the same with the front, I found no obvious break. Suspecting the connector was faulty I bypassed it, but found no relief.
I am hoping someone would be able to help me understand where the wire would terminate so I can trace the entire wire and figure out if I need to route an overlay to bypass the faulty wire. I have tried tracing it myself up through the wheel well into the engine compartment, but without tearing the harness apart I can't identify where it goes.
I have tried to look for RAVE manuals which might have this information, but haven't been too lucky yet. Local dealership wants to charge 8 hours just to diagnose and they run 235 an hour and would like to avoid that if possible.
Located in Southern Indiana, looking for any help or tips anyone can offer to try to understand how to better locate the problem.
