Hey guys,
I know this has probably been beat to death, but I need to get this fixed. When I start the truck it throws all of these faults on the screen. Sometimes it will be very low suspension wise. I've replaced both front air shocks. Never touched the rear or the compressor. Is it probable that it's one of the rear shocks or the compressor? Any thing else you suggest I look at? Thanks.
It most likely a low battery. When the battery or any part of the charging circuit get weak you get all sorts of errors transmission fault is usually the first one.
Run through the tests in the electric trouble shooting stickie
