I have a problem with the parking sensors. I replaced a couple of sensors as the system didn't work at all. On test n reverse with engine not running
all the sensors are now working as they should. As I approach each sensor they all beep in the car and quicker as I get closer. But when the engine is running and I select reverse they go haywire and the system beeps front and back for no reason even if the car is nowhere near any obstacles. Any ideas
Check all your grounds especially the ones in the battery and wheel arch area.
Attached the info and wiring for the system to aid your mission.
The parking Aid system stores codes and they can be read with the correct tool.
