I have searched, but no luck. The mirrors will not stay where programmed. I get in, put them where I want them, hit the memory to keep them there. Stop, get out and when I get back in, I have to do put them back into position again. This happens every time I get in and startup. Any advice would be appreciated.
Minor detail question. Are just hitting the memory button or are hitting the memory button and assigning to number that corresponds to the key you are using? If you are using the number 1 key you need to hit the memory button and the "1" button. Every time you unlock your Rover the seat mirrors etc will return to whatever settings are assigned to that key.
If it isn't what RRToadHall says then it may be your memory module is shot. I had mine replaced 3 or 4 times in the first few years.
