Discussion Starter · #1 · (Edited)
2007 RR suspension height limits, can you reprogram back to 2006 specs?
(content deleted, I intended to post of the L322 forum, not the L320)
Re: 2007 RR suspension height limits, can you reprogram back to 2006 specs?
I may be wrong, and will have to double check some files I don't have on this computer, but according to the specs I have, 03-09 L322s all have 270mm/330mm of wheel articulation front/rear, when both wheels moving at the same rate(sway bars will limit individual wheel travel)
The main difference that I know of between the 03-06NA and 06SC-09 front struts is the built in castor angles, slightly less positive for the +07, and the mass dampener installed on the SC versions.
Also, terrain response is solely an output to different systems, so it really doesn't do anything, just tells other things how they should be working, such as changing throttle opening speeds, changing **** points, or limiting ABS activation.
