Can someone please tell me where the radiator drain valve is located on my 2007 RR sport SC? I want to change my coolant and can't seem to find the valve to drain the radiator. thank you
Did you check for a plug on the bottom of the radiator? I hope there's a plug/petcock hiding somewhere, otherwise its thar she blows if you have to remove the hose.
Thank you, but where is the front LH splash shield located? The picture is difficult for me to visualize. Is it in the engine compartment or under the car to access it? Thank you so much.
