More pictures of the car.
Your engine cover has been re painted but not by JLR.Hello everyone. I recently purchased a beauty. The car only has 67k. It is not my first supercharged and I can tell the difference. This one seems more powerful and the gearing seems different too (more sporty). It also has a red engine cover (repainted I think) with Overfinch logo. Does anyone know what modification they were doing enginewise at the time? I have attached some pictures. Thanks. Maxime View attachment 308589
No Overfinch lettering on hood, bootlid, brakes. The sills don't look Overfinch either. No Overfinch front/rear bumpers, although the exhaust is non-stock. No Overfinch wheels. The engine cover was painted by a butcher, horrendous job.This one seems more powerful and the gearing seems different too (more sporty).
Thanks for your message and your thoughts about the engine, the car, and its modifications.No Overfinch lettering on hood, bootlid, brakes. The sills don't look Overfinch either. No Overfinch front/rear bumpers, although the exhaust is non-stock. No Overfinch wheels. The engine cover was painted by a butcher, horrendous job.
Overfinch logo ovals are $20 each, wheel caps $30 (I know, I bought 4 recently).
Overfinch didn't do any transmission or diff changes. You may have a smaller supercharger pulley. Perhaps a sharper transmission tune, but the only place I know that remaps 6HP in Land Rovers is in Australia so I assume the transmission just seems to shift more aggressively because of the engine output.
Do yourself a favor and run the VIN through Overfinch themselves. It will save you a lot of headaches once you know what this car consists of and where it came from.
Appreciate it Thanks!Your engine cover has been re painted but not by JLR.
Very nice RR L322 by the way you're lucky to pick up one with such low mileage.
Found this one as well.By the way, doing my research, I think I found the sweetest L322 Overfinch of them all!! I love everything except maybe the wheels.
I will definitely do that. Thanks.Found this one as well.
Re: VIN - perhaps JLR will know whether it has been delivered to O/F directly or maybe someone added the bodykit and goodies post-factum. This would explain the lack of brakes and maybe the lettering situation.
The supercharger pulley is exceptionally easy to spot - you only need a ruler and measure the diameter.
Hey Luis, thanks for your response.I believe I’ve seen Chinese made aftermarket Overfinch parts on Supertweak.
Personally, I don’t care for the Overfinch look.
As for engine tuning, I had Eurocharged Performance dynotune my 4.2. It’s rated at 453 HP and 490 ft/lbs. I prefer the sleeper effect anyway. The only hint that mine isn’t stock is the Magnaflow exhaust.
They are similar though Eurocharged is not a plug and play kit. It is a flashing of the ECU.Hey Luis, thanks for your response.
How is the dynotune? has it drastically changed the car? Is it something like this:
VR Tuned ECU Flash Tune Range Rover III L322 4.2L V8 Supercharged 400HP | VRT-RR-III-396
VR Tuned ECU Flash Tune Range Rover III L322 4.2L V8 Supercharged 400HPwww.vividracing.com
I would love to see a picture of your car. How many miles now?
I love the spec!They are similar though Eurocharged is not a plug and play kit. It is a flashing of the ECU.
Both kits seem to get about the same HP but Eurocharged gets more torque.
