I'm considering upgrading from my current 2002 P38 to a 2007/08 Full Size RR and am wondering if the extra cost of the Supercharged edition is really worth it? If I seek out a normal HSE version I would definitely look for one with the luxury package as that has some of the options I would want. I'm not all that concerned with the extra power of the SC version as going from the P38 to a HSE L322 will be a big increase in power by itself, though extra power isn't a bad thing if it doesn't come at the cost of a shortened engine lifespan. And besides the RR, is in my opinion, a truck and not expected to post zero to 100 times alongside a Ford GT40 or corner like a BMW M3. My main questions are long-term maintenance and reliability on a SC model. How is the reliability of the SC itself, ie seals, bearings, cooling, etc... How does the SC effect the engine itself? I assume the boost level isn't high enough to cause a reduced engine life? I heard on here that the Brembo brakes on the SC version were a more expensive maintenance item, but a quick internet search shows that at least the pads are no more expensive and calipers can be rebuilt vs replaced fairly reasonably. Are the struts different between the two and given that these should be considered a wear item are the SC ones more costly?
If the HSE and SC are equally reliable and equal in maintenance costs then I guess it's just a matter of driving each one and determining for myself if the extra cost of having extra HP, all the options of the HSE's luxury package in the SC model and the firmer suspension are worth the extra couple of thousand dollars.
Thanks for all your opinions
