Hi All!
I am trying to figure out where an oil leak is coming from. The attached picture is looking down behind the right headlamp assembly. The pbit circled is a cooler that draws air in from the lower front bumper and vents into the right front wheel well. The air points to a line that runs straight down and goes under the radiator. I have not traced it further yet. I appears that line is leaking, the oil is running down and dripping on the lower air dam. What is that cooler and that line? Is that my problem?
Thanks,
Dave
Dave,
Photo?
Auto part Wire Bumper Automotive fuel system
OK, lets see if this works. The upload function was not working for me when I posted this.
Dave, any luck in finding out the source of the leak? I'll want to compare yours with mine
That is your auxiliary engine oil cooler.
