You could pull the lines and bring them to a hydraulics shop. Any agricultural supply place should be able to point you in the direction of one. I had a line built for a Disco 2 with active swaybars years ago.
You might be able to grab the regular sway bars from junk yard and disable the active sway control or whatever it is called on the RRS. Again, might be able!
Mechanically I can't see any reason for it not being possible. You would need the sway bars, swaybar links and sway bar bushes. You would also need to put a shorter serpentine belt on bypassing the ACE pump.
Electronically, I have no idea! Somebody else might help you.
