Hi, my Rover has adaptive headlights and the left one (passenger) is bipolar. Sometimes after calibration it’s level, and sometimes it’s stuck in the low position. They both calibrate in-sync but then sometimes the left one stays low. They both still move horizontally while turning no problem, and I can manually adjust the left one when needed, the only problem is after I adjust it and the next time it’s level, I have to readjust it. Already swapped power modules to see if that was it... problem stayed on the left side. And thoughts?
Do you have a diagnostics tool such as an iid-tool? Ever since I bought my rrs, the left headlight has always stayed pointing down the same as yours. I only just discovered tonight, that I had a fault code for no data for left headlight level. I cleared that and suddenly both headlights are level. I don't know if the problem will come back, but it's something worth trying if you have access to a diagnostics tool.
