Hello,
I recently purchased 2006 RR SC. The front lighter is not working. I checked fuses and they are good. I need to access wiring for lighter to diagnose problem. I have searched for directions to remove center console, but I haven't had any luck finding instructions for console similar to my car. I'm open to any suggestions.
Thanks,
Lou
https://goo.gl/photos/eagEpqeZdGZRQcDN8
Hello,
Thanks,
Lou
I have the same issue with no power there, I'll be keeping my eye on this post.
Today I removed the center console to access the Lighter. The lighter is not getting power... I tested the leads that attach to lighter with with multi-meter. I also checked fuse #2 in the dash, and fuse #1 in rear with multi meter. I did notice the rear fuse was 15amp, and I believe the manual specifies a 20amp.
Pry up on Back of Shifter Surround:
Remove the 4 torx Screws under shifter surround
Remove Cup holder by pulling straight up, and remove two torx holding center console.
Lift straight up on center console to get access to lighter from side.
I discovered the green plastic surround on my lighter was broken during previous service, and I was able to push the lighter up from the bottom. When I was going through the paper work from previous owner. I noticed that the dealer had addressed the complaint that lighter wasn't working the end of October. The tech must have been in a huge hurry because some of the trim clips were missing. They must have fallen off, or possibly were broken during the repair, but they were left off.
I haven't had any luck figuring out why the lighter isn't getting power, but I'm open to suggestions.
I also measured the trim clips, and went to auto zone where I found a similar clip for jeep. I'll post picture of RR Clip.
