1 - 1 of 1 Posts
recently, my LH front window stopped working. All other windows work normally. When I activate/hold the switch, I hear a click----maybe like a motor overload or something----same up or down. I decided maybe was motor, so I bought a replacement motor/regulator asm so I would have when I took apart. Well today, I took off the door card. Before I did any take apart, I put wire on new regulator and it worked. I then took out the current motor and activated it--it worked. So, I thought it must be regulator----so I figured out how to exchange it-----hooked it up----the door glass was about 3" down-----I raised it---- now the window is doing the same thing as before---not working. but is clicking. Is there a reset procedure or something, or do I need to check the RH door sill harness topic I see in the forums? I will appreciate any help on this. I am stumped.
1 - 1 of 1 Posts
