Just thought I would document the known history of my 2006 HSE as I am making some substantial repairs at 114,000 miles.
Previous Owners (before December 29, 2016 and <102,00 miles):
My repairs (After December 29, 2016 and >102,000 miles)
I will add to this thread for posterity as repairs continue over time...
- Front Air Springs replaced with Arnott (Date/Mileage Unknown)
- Ignition swap to 2008 model (date/mileage unknown)
- Steering column swap to 2008 (date/mileage unknown)
- Replace Main Control Valve Body/Solenoids in response to fault codes P0741 and P0730 (1/20/2017 - 102,157 miles)
- Coolant Sensor Wire repair at firewall (1/20/2017 - 102,157 miles)
- Replace Front Lower Rearward Control Arms (1/20/2017 - 102,331 miles)
- Replace Brake Pads and Rotors all 4 corners (1/20/2017 - 102,331 miles)
- Remount Subwoofer to eliminate rattle (1/20/2017 - 102,331 miles)
- Replace Stabilizer Bar Control Links (1/25/2017 - 102,331)
- Replace AC Compressor (6/15/2017 - unknown mileage)
- Replace Tail Light Housings (6/15/2017 - unknown mileage)
- Replace all four Ride Height Sensors (11/16/2018 - 114,550)
- Replace Tie Rod Ends - Inner (11/16/2018 - 114,550)
- Replace Tie Rod Ends - Outer (11/16/2018 - 114,550)
- Replace rear air springs with Arnott (11/16/2018 - 114,550)
- Replace rear Shock Absorbers (11/16/2018 - 114,550)
- Replace Front Lower Rearward Control Arms under Mechanic Warranty (11/16/2018 - 114,550)
- Replace serpentine belt (11/16/2018 - 114,550)
- Repair wiring failure for 4-Low switch (11/16/2018 - 114,550)
