2013-2015 Range Rover Sport
I have a 2005 RR Sport S/C with severe suspension issues. It shows Vehicle Lean When Cornering and also a HDC fault. When you drive the car it feels unstable, with the front floating. There are no obvious signs of the suspension leaking. I assume the suspension constantly automatically adjusts itself when driving, pumping up each corner when under pressure such as going around a tight bend. This is not happening and it leans heavily into the bend. Any thoughts?
Discussion Starter #2
As an update one of the rear tie rod bolts was loose which was causing the psychotic handling. Now this is fixed and with a new prop shaft which had a mashed centre bearing things are better. The leaning issue is still a problem though - any ideas how to fix this "Vehicle Lean When Cornering".
