On the top of the Crankcase Vent Valve, there are two yellow fittings. The one on the left is plugged. Does anyone know where the small vacuum hose is going that connects to the right side yellow fitting?
Discussion Starter #2
IIRC, after thinking about this, both of mine were plugged, as I don't see any loose vacuum lines in the engine compartment....but, would like confirmation on someone that has a 2005....
Range Rover MkIII / L322
It would normally route via a canister and SAI solenoid valve to the secondary injection valve but was deleted in 2004 so your car wont have.
So they both need to be plugged.
Ignore my previous post, misread and thought the question was about the vent pipe in the foreground.
NP, I thought that's what you were looking at. BTW, per GHUR, I plugged both vent outlets.
