I am replacing the wiring harness on my front left(drivers) side ride height sensor on my 2004 range rover however i cant tell which wire the red, blue, and yellow off the new harness should connect to. The old wires seem to be faded and I thought I had them connected correctly however no matter how i connect the wires it is saying on my hand held that its getting roughly 40v while the others are getting 2v. Any help would be great. thanks
Wiring diagram is in the ETM in RAVE. You can also pull the harness cover back further to get to the actual wire colours.
hey, i found the pins with the wires for the sensor however would you know on the harness what each color the red, blue, yellow stand for. not sure which is power,ground and signal. thank you
