Hey everyone,
Hoping somebody can help me out with a problem I’m having with my 2004 Range Rover. When I’m driving at a consistent cruising speed with low rpms (doesn’t seem to matter what gear) there’s an intermittent hum/groan noise. Occasionally there’s a shudder but that doesn’t happen as often. When I’m accelerating there’s no issue and when I’m on the highway at cruising speeds there’s no issue. It just seems to be between 25-55mph at low rpm. If I go under and disconnect the transfer case shift actuator the noise goes away. However of course I want it connected. Took it to a couple local independent shops and they weren’t much help. No lights on the dash, no codes, everything else works great. Thanks in advance!
-Cheers,
Brad
-Cheers,
Brad
