1 - 10 of 10 Posts
Hello all.. One of my low beam lights is out on my 2004 Range Rover. Is there a particular brand and model you all would recommend as a replacement? I was going to swing by autozone in the morning to buy but can order online if I need to. This will be my first time replacing the bulb. Can someone tell me the model and do I need to take the entire headlight out to replace?
2010 SC 5.0 Range Rover MkIII / L322
what kind of headlamps do you have?
HID or halogen?
I believe they are Halogen. How would I tell? I have not done any upgrades. They have always been replaced by the dealer. Figured I would do them this time around.
RIP Our Friend
If one is out replace both as they yellow with age. We didn't have HID in 2004. Low beam and high beam are both halogen H7 here in the NAS market. Pull one out and check if it's 2 prog, single element. The fluting within the head lamp assembly aims them differently You can pick up a 2 pack of Sylvania Xtra Vision H7 at Walmart for under $20 or about $25 at Oreilly's
RIP Our Friend
must be late 2004 then because the 2005 manual lists bi xenon have you swapped the ballasts or bulbs to make sure it's bulb?
My 2004 has HID bulbs for the headlights. High beams are halogen. Osram 6000K are OEM bulb (watch out for counterfeit on eBay).
1 - 10 of 10 Posts
