Hi I've tried searching everywhere (I've tried searching the forum and on ALLdata) to find the AC drain hose location but am not having any luck! I have a 2004 Range Rover HSE that is getting a lot of condensation coming out of the rear AC vents and occasionally out of the front. There also seems to be damp spots on the passenger side floor after using the AC. Any help/pics of the drain locations would be appreciated!
It is not a single hose. It is a pair of hoses that drop from each side of the heater box through the floor to each side of the transmission hump. You need to raise to wading height, crawl under and squeeze the two nipples poking through the floor. If they are completely plugged you'll need to run something flexible like network cable up through the lines
RRToadHall thanks so much for the quick reply! Finally managed to find them, hopefully getting it cleaned out will take care of the problem!
