]hi guys I got the Trans fail safe warning message ping up today along with the car locking to 4th gear (can't change gears manually either). I managed to limp the car home and hooked my icarsoft scanner up which is throwing the following faults:
P0755 State: Plausability Fault. Shift Solenoid B1 State: None. Shift solenoid 2 Fault
Does anyone have any idea on what the cause of this fault code is and how to go about fixing it, thanks in advance for any help
