1 - 9 of 9 Posts
Ive just bout a nice 2003 Vogue but it has a few small issues? Ill post them up 1 at a time.
The electric adjustment on the steering wheel works up and down but not in and out. Is this a common problem and is it a DIY fix?
Many thanks in advance :)
From what I gather very common. The plastic bracket that holds the electric motor in breaks, which then falls out. Mine was broken as well. When I was replacing the steering angle sensor the motor was just flopping about. Easy enough to repair.
Thanks for the reply, Is just a repair or do i need to get any replacement parts?? Also where is it situated and how easy is it to access?
you need a replacement bracket i've just bought one from rimmer bros, they only have one left part number qyh5000030 it's around £37 delivered
I think you will need to remove the lower dashpad in order to access it. As for parts, technically the bracket is broken. I built my own that will outlast the car.
i'm interested in how thy are removed, i think they just clip on on trim clips for the majority
You have to remove everything. It is a horrible, horrible job to remove the lower dash pad. Side covers, all the vents, glovebox, kick panels, all of it.
1 - 9 of 9 Posts
