Good afternoon. I have stumbled upon a 2003 rover for sale (needs work).
It has 88,000 miles on it and needs the following:
Water Pump and Gasket Replacement
Upper and Lower Radiator Replacement
Thermostat and Gasket Replacement
Front and Rear Brakes
Tune Up
I am fairly mechanically inclined (have learned A LOT more since owning a P38!), and I price the parts out to be roughly $1,300. Asking price is $13,000 OBO, I was thinking of throwing 9k at it. Worth it?
Tune Up
if everything else is solid and minimal wear I'd say if you get it at $9k that would be a deal.
I guess all I can say is make sure you're sure...check everything...that seems like a good deal if you check the blue book value (I'm assuming it's from a private seller), but not if you're going to drive it 5k miles and have to replace a ton of stuff.
I think there's a 90K mile service that would be coming up, so be ready for that.
Best of Luck
Might be a good deal as long as the airbags are good. If your looking at spending that kind of money. I would sell you mine 2004 Range Rover HSE with 2 extra tires (so 4 tires on the car and 2 tires off). 73,000 miles.
Mine has the Cold weather package which some don't, which means it has heated seats x 4, heated steering wheel.
Has new rear brakes as of 2 weeks ago.
Has bluetooth parrot car kit (plays over the factory range rover speakers)
Has a remote start system (3000 FT range) 2 way will confirm that your vehicle started on the remote
Mine is bonnati grey (so its not black)
I would let mine go around $20k
