Hey guys, I was wondering if it's possible to swap out the subwoofers in my 03' l322 with an upgraded aftermarket set of 6.5''.
Would it all be plug and play?
Or do you think my best/easiest option is to order the OEM subwoofers, and swap them out with the blown subs that are currently installed.
Thank you.
Either way - just be careful to match the power and impedance. It might not be plug and play as the aftermarket speakers will likely not have the same connectors - but that's not much of a hurdle. The hole patterns might be different too - but again that can be surmounted.
