Would a 305/40/22 fit or would it be too wide? I know most people go with 285/35 or 285/40 but just wanted to know if these would work on there.
Thanks!
Thanks!
You want to keep the same total diameter, what if you end up on bump stops/access mode and it rubs? Not worth it!ZambeziHSE03 said:Well it seems like they shouldn't be too tall since there is enough height clearance?
Yup that kind of difference could also lead to problems with the Gearbox, Differential & Transfer Box as well as the Speedometer and all other calculation including Service Interval being wrong!ZambeziHSE03 said:Well it seems like they shouldn't be too tall since there is enough height clearance?
You need the 285/35/22 to keep within the required margins....ZambeziHSE03 said:Thanks!
I got some brand new 22" Stormers with new 265/35/22 locally and the sidewall is too small so I am going to get either 285/40/22 or 285/35/22 this week.
If you say so but thats a 73mm bigger circumference (3 inches) over stock design :think:krunkman said:285/40/22 is absolutely the only way to go.
Had 285/35/22 before and there is just too much gap, looks horrible and rides like Golly Gee Whiz.
That sounds worse than it is.Gazellio said:If you say so but thats a 73mm bigger circumference (3 inches) over stock design :think:krunkman said:285/40/22 is absolutely the only way to go.
Neither of the above is stock though!!!krunkman said:That sounds worse than it is.Gazellio said:If you say so but thats a 73mm bigger circumference (3 inches) over stock design :think:krunkman said:285/40/22 is absolutely the only way to go.
285/35/22 Diameter is 29.9 inches
285/40/22 Diameter is 31inches
http://www.miata.net/garage/tirecalc.html
