1 - 9 of 9 Posts
The web has too many options. I can measure mine in inches but it seems that mm is the preferred measurement of seat belt type.
I have no way of measuring mm precisely. I have contacted seatbelt extension pros and have shopped for a 5” rigid grey extension but there system lists nothing. Rather then buy and return until I can figure it out.
Would someone with a micrometer measure the length width and depth of the male part of the rear passenger seatbelts for me? I would be great full.
Thanks in advance.
2002 P38A NAS Black On Ash Grey.
IF you are after an extension, why not visit a wreckers and chop out the parts you need and have them made up by a competent shop?
Probably cost less and it will be exactly as you want it.
I would bet the seat belt hardware is the same on all years as well
(I am sure if I am mistaken on that OB will correct me :naughty: )
Well Mr Digby..... :)
Broadly there seem to be 2 groups of rear belts in Microcat, pre and post Thor.
What are also listed are "Extra Long" rear seat belts-
RH. To WA410481. EVL000160LNF
LH. To WA410481. EVL000170LNF
RH. From XA410482. EVL000100LNF
LH. From XA410482. EVL000110LNF
Hmmm. Apparently you can no longer edit posts older than 15 mins on here, so I'll tag this on:
You can certainly buy them in UK. Love the fact they're marketed as "Big Man"
http://www.brit-car.co.uk/section.php/8035/1/front___rear_seat_belts___big_man______cdn_mex_usa__
Looks like they're available in US. Lots pop up on Google. This sample, for instance
https://www.jaguarlandroverpartstore.com/oem-parts/land-rover-seat-belt-evl000160lnf
HA! See? Yet another gaff caught by OB! Thanks. I was unaware that they changed over with engine change BMW?
So, OB, Ya know who Digby is eh?......Yep, that one......
I will when I get back from my business trip.
I just heard back from seatbelt extension pros and the Range Rover P38 is a TYPE S connector. It is listed for Jaguar/ Range Rover So I ordered a 5” RIGID Grey extension for the rear passenger window to work with my child’s Clek Oober booster seat. Hopefully it will matched the Ash Grey Interior. I’ll update if it doesn’t work.
Thanks for all the help.
1 - 9 of 9 Posts
