Hi All i have an issue with my 2002 TD6 :-( starts but if you put your foot down at all it just ignores you, will slowly accelerate but god help you if you hit a hill!
checked the in tank fuel pump and can hear that running when you turn on the ignition (shuts off after about 30 seconds presumably got up to pressure) changed the fuel filter just in case but still wouldn't pull the skin off a rice pudding.
I think this is a fueling issue (though not sure) no faults on the dash.
anyone else encountered this type of problem? does any one know an easy test on the high pressure rail as i'm starting to suspect the high pressure pump or is there something i'm missing that i should check first?
Cheers Stuart
Cheers Stuart
